  4. paraview无故黑屏
paraview无故黑屏
16 帖子 5 发布者 28.3k 浏览
    Samuel-Tu
    哎,最近试了一下把桌面管理系统改回去。以前的桌面管理系统是gdm3,改回去后,paraview还是打开时是黑屏的,但是以前就没问题,我现在真的搞晕了。。
    设置独显和集显的方法,大家又链接推荐下吗,搜到的都没有用。。。
    gdm 是桌面管理系统,不是桌面。就是 gdm 是用来选用哪个桌面的,只在登录界面是用到。实际桌面是 gnome-shell 或者 gnome-panel 之类的。
    如果确定切回 gnome 桌面了,再新建个用户,用新用户开 paraview ,确定不被历史配置文件影响。新用户下还不行,就去 paraview 官网下载最新版二进制包。
    linux 的独显驱动是个很麻烦很麻烦的事情,如果是 nvidia 的,搜搜bumblebee,就是变形金刚里面的大黄蜂的英文名。这个还算简洁的。非常取决于你的具体环境,步骤比较多,还要修改系统配置文件啥的。
    如果翻不了墙,用 bing 的国际版搜,把你的问题用英文描述,stackoverflow 或者 linux 发行版的论坛 ,比如 ubuntu 论坛的质量比较高。
    Samuel-Tu
    @bestucan 好滴,太感谢了
    Samuel-Tu
    在cfd-online里面找到了一个解决方法,看起来是换了显卡驱动。。我还没有试,现在是远程操控,重启电脑,我就操控不了了。。
    I was facing black screen error when I open ParaView 5.6.0 in Ubuntu 18.04. The issue is NOT WITH PARAVIEW at all. It's an issue with the graphics card. Basically what's happening is that paraview is loading correctly but is not getting rendered on the screen.
    For me, it was resolved by updating the graphics driver. The procedure is as discussed below:
    I'm using a HP Z2 PC with NVIDIA Graphics card. Just needed to install the latest NVIDIA graphics driver and the paraview started working like a charm:
    1. Open "Softwares and Updates" window from the Applications
    2. Go to "Additional Drivers" tab. It will show a list of drivers
    3. Choose the latest driver for NVIDIA and click on "Apply Changes". For me, it was nvidia-driver-430.
    4. It will show a prompt for a secure boot password. Basically, this is an additional layer of security to allow proprietary software (such as this driver) to load everytime you logon.
    5. After installation, reboot the system. It will take you to MOK Manager.
    6. Click on "Change Secure Boot State" and then "Enroll key" and enter the secure boot password you've set while installing the driver. This step needs to be done only the first time you reboot after driver installation.
    7. After the reboot, check the current driver: Settings> Details> About. The graphics information should now be updated.
      For more info on updating the graphics, check the page: https://www.linuxbabe.com/ubuntu/ins...r-ubuntu-18-04
    linux那个显卡特别费事,2011年我刚学openfoam的时候,折腾一星期,后来彻底放弃了,到现在也不想渗入..
    Samuel-Tu
    【unbuntu换显卡血泪干货】
    ubuntu18.04用了向日葵远程连接老是会假死,只能换桌面控制系统lightdm。然而一换桌面控制系统,后处理软件paraview又打不开了,原因在于换了桌面控制系统后,显卡不支持paraview了。这是一个死循环。然而在我研究了一周后,终于找到了解决办法,换成英伟达的显卡!以下是操作:
    【干货】
    sudo ubuntu-drivers autoinstall
    自动安装后会叫你输入一个密码用于一会开机验证8-16个字符
    reboot重启
    重启后进入perform mok management界面
    选择enrol mok
    选择enrol the key
    选择yes
    输入开始设置的那个密码
    然后会自动reboot重启
    然后就换成功了。。
    【血泪】
    开始在perform mok management界面选错了,一度黑屏,吓得我以为要重装系统了,所有数据全部会丢失。好在我一波挽狂澜于即倒,ctrl+alt+F2进入命令行模式,重新按【干货】操作了了一波,成功改过显卡。。所以没把握千万别乱动系统显卡。。差点完蛋,吓得我赶紧把所有数据代码拷贝到我的移动硬盘里。。
    F 1 条回复 最后回复
    只要你没有明确的格式化你的硬盘,你的数据就不会丢失。只是从一个带系统的硬盘变成了大U盘。
    Ctrl + alt + F1~F7 都算可以调出来终端,一般前两个或最后一个是图形的。
    即使上面七个都挂了,grub 里还有一个,Linux 没那么容易崩的:mihu:
    这就是 linux 难推广的地方,很多经验并不相通,ubuntu-drivers 是 ubuntu 自己搞的,debian 系的并不通用,这是开始夹私货了。
  • F 离线
    F 离线
    fengxxss
    在 中回复了 Samuel-Tu 最后由 编辑
    @Samuel-Tu 太有用了!!!不过我只进行了第一步sudo ubuntu-drivers autoinstall后面重启没有进入其他页面,但是问题也解决了!!
    @bestucan 屌爆了 大佬
    bestucanB 1 条回复 最后回复
    @李东岳 无意中帮到大佬被cue:143:
