  4. 圆柱绕流 高雷诺数10e5
圆柱绕流 高雷诺数10e5
25 帖子 5 发布者 24.3k 浏览
    lwf
    圆柱绕流在低雷诺数(600左右)的时候使用icoFoam能正常计算(nu=0.08),把nu改为10e-5后,加入了湍流模型,用pisoFoam 求解,但在计算一开始就会直接爆掉,最大库朗数1600多,怎么改都算不了,不知道为啥,请大家指点一下?是网格的原因吗还是我的设置问题?
    圆柱直径4m,入流10m/s,网格量大概190000。用的k-epsilon,时间步长原本用的是0.005,后面改成0.0005了也不行,应该是设置问题,但不知道是哪。
    贴一下信息
    log
    Courant Number mean: 1.64478e+27 max: 6.7649463e+34
    Time = 0.006
    PIMPLE: iteration 1
    smoothSolver:  Solving for Ux, Initial residual = 0.99999999, Final residual = 6.1529517e-10, No Iterations 1
    smoothSolver:  Solving for Uy, Initial residual = 0.99731182, Final residual = 1.7252366e-11, No Iterations 1
    [2] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [2] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [2] #2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
    [2] #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    [2] #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [2] #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [2] #6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [2] #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
    [2] #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
    [2] #9  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
    [2] #10  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    [2] #11  ? in ~/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/pimpleFoam
    [hipeson-X12DPi-N-T-6:358676] *** Process received signal ***
    [hipeson-X12DPi-N-T-6:358676] Signal: Floating point exception (8)
    [hipeson-X12DPi-N-T-6:358676] Signal code:  (-6)
    [hipeson-X12DPi-N-T-6:358676] Failing at address: 0x3e800057914
    [hipeson-X12DPi-N-T-6:358676] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420)[0x7f9c482c6420]
    [hipeson-X12DPi-N-T-6:358676] [ 1] /lib/x86_64-linux-gnu/libpthread.so.0(raise+0xcb)[0x7f9c482c62ab]
    [hipeson-X12DPi-N-T-6:358676] [ 2] /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420)[0x7f9c482c6420]
    [hipeson-X12DPi-N-T-6:358676] [ 3] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0x242)[0x7f9c48dc4792]
    [hipeson-X12DPi-N-T-6:358676] [ 4] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0x8ea)[0x7f9c48dc634a]
    [hipeson-X12DPi-N-T-6:358676] [ 5] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x668)[0x7f9c48dc8658]
    [hipeson-X12DPi-N-T-6:358676] [ 6] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x625)[0x7f9c4c7200d5]
    [hipeson-X12DPi-N-T-6:358676] [ 7] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x498)[0x7f9c4bea8728]
    [hipeson-X12DPi-N-T-6:358676] [ 8] /home/hipeson/OpenFOAM/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28)[0x7f9c4be412e8]
    [hipeson-X12DPi-N-T-6:358676] [ 9] pimpleFoam(+0x2fc8c)[0x55fd9630cc8c]
    [hipeson-X12DPi-N-T-6:358676] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f9c480e4083]
    [hipeson-X12DPi-N-T-6:358676] [11] pimpleFoam(+0x32aae)[0x55fd9630faae]
    [hipeson-X12DPi-N-T-6:358676] *** End of error message ***
    mpirun noticed that process rank 2 with PID 0 on node hipeson-X12DPi-N-T-6 exited on signal 8 (Floating point exception).
    U
    internalField   uniform (9 0 0);
    boundaryField
        INLET
            type            fixedValue;
            value           uniform (9 0 0);
        OUTLET
            type            zeroGradient;
        WALL
            type            slip;
        CYLINDER
            type            fixedValue;
        frontAndBackPlanes
            type            empty;
    P
    internalField   uniform 0;
    boundaryField
        INLET
            type            zeroGradient;
        OUTLET
            type            fixedValue;
            value           uniform 0;
        WALL
            type            zeroGradient;
        CYLINDER
            type            zeroGradient;
        frontAndBackPlanes
            type            empty;
    k
    internalField   uniform 0.375;
    boundaryField
        INLET
            type            fixedValue;
            value           uniform 0.375;
        OUTLET
            type            zeroGradient;
        WALL
            type            kqRWallFunction;
        CYLINDER
        frontAndBackPlanes
            type            empty;
    nut
    boundaryField
        INLET
            type            calculated;
            value           uniform 0;
        OUTLET
            type            calculated;
            value           uniform 0;
        WALL
            value           uniform 0;
        CYLINDER
            value           uniform 0;
        frontAndBackPlanes
            type            empty;
    epsilon
    dimensions      [0 2 -3 0 0 0 0];
    internalField   uniform 0.07;
    boundaryField
        INLET
            type            fixedValue;
            value           uniform 0.07;
        OUTLET
            type            zeroGradient;
        WALL
            type            epsilonWallFunction;
            value           uniform 0.07;
        CYLINDER
            value           uniform 0.07;
        frontAndBackPlanes
            type            empty;
    感谢大家帮助!
    Afr1yne
    把fvSolution中压力求解器改成PCG试试
    lwf
    谢谢,我试了一下,还是不行,我网格用ICEM画的,网格质量很高,就是不知道哪出的问题。还请大家指教一下
    fvsolution
    solvers
        p
            solver          PCG;
            preconditioner  DIC;
            tolerance       1e-06;
            relTol          0.05;
        pFinal
            $p;
            relTol          0;
        "(U|k|epsilon)"
            solver          smoothSolver;
            tolerance       1e-05;
            relTol          0.1;
        "(U|k|epsilon)Final"
            $U;
            relTol          0;
    PIMPLE
        nNonOrthogonalCorrectors 0;
        nCorrectors         2;
    fvscheme
    ddtSchemes
        default         backWard;
    gradSchemes
        default         Gauss linear;
    divSchemes
        default         none;
        div(phi,U)      Gauss linearUpwind grad(U);
        turbulence      Gauss upwind;
        div(phi,k)      $turbulence;
        div(phi,epsilon) $turbulence;
        div(phi,nuTilda) $turbulence;
        div(phi,R)      $turbulence;
        div(R)          Gauss linear;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    时间步长缩小
    lwf
    感谢李老师,我再试试
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火丙三金
    在 中回复了 lwf 最后由 编辑
    @lwf 怎么样兄弟
    lwf
    在 中回复了 火丙三金 最后由 编辑
    @火丙三金 我改完后跑出来的结果感觉不对,没有涡脱落,fluent倒是能跑出来涡脱落,改到崩溃,看着不合理,水平不行...
    LES的结果:
    RANS的结果:
    火 李东岳李 2 条回复 最后回复
  • 火 离线
    火 离线
    火丙三金
    在 中回复了 lwf 最后由 编辑
    @lwf fluent可以分享一下嘛 我也来改一改!
    在 中回复了 lwf 最后由 编辑
    @lwf openfoam那个你要算充分长的时间,前期需要发展
    lwf
    在 中回复了 火丙三金 最后由 编辑
    @火丙三金 fluent的简单,把网格导进去设置一下就行,我把网格贴上来。ICM-11_10wan.zip
    foam里面低雷诺数倒是正常
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火丙三金
    在 中回复了 lwf 最后由 编辑
    @lwf 我来试着调一调 兄弟没试下圆形区域嘛
    你这个算例有几处不太合理的地方:
    1. 估计你的网格是边界层首层厚度很小的那种吧,那么你用 standard k epsilon 这个湍流模型是不合适的,建议使用 kOmegaSST。
    2. 抛开 k-epsilon 模型的合理性不谈,你这个 k epsilon nut 的 Inlet 边界条件设置也是不合理的。首先,你的入口速度是 9m/s,k 的 Inlet 值为 0.375,意味着入口湍流度为约 5.5%,这个值是偏大的。而 epsilon 的如何值为 0.07,意味着入口的 nut 值为 0.09*0.375^2/0.07=0.1808,超过流体粘度的 10000倍,这个是严重偏大的值。
    lwf
    @李东岳 李老师,LES和RANS都需要前期充分发展时间吗,怎么fluent里面很快就能出现涡脱落?
    lwf
    在 中回复了 xpqiu 最后由 编辑
    @xpqiu 非常感谢提醒,请问有可以计算模型边界初始值的参考资料吗
    lwf
    在 中回复了 火丙三金 最后由 编辑
    @火丙三金 计算域圆形矩形不大吧,圆形也试过,现在就是我设置的问题,模型和边界条件不合理
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火丙三金
    在 中回复了 lwf 最后由 编辑
    @lwf OK 我拿fluent试试
    在 中回复了 lwf 最后由 李东岳 编辑
    @lwf 都需要。你可以把你的RANS的nut截图发上来看一下。是URANS么
    lwf
    @李东岳 李老师,因为不知道怎么设初始值合适,所以我当时是参照foam里面其他案例设置的nut,用的piso,这应该属于URANS吧,我看论坛以前讨论过RANS是用稳态模拟,URANS是瞬态模拟。
    nut:
    boundaryField
        INLET
            type            calculated;
            value           uniform 0;
        OUTLET
            type            calculated;
            value           uniform 0;
        WALL
            value           uniform 0;
        CYLINDER
            value           uniform 0;
        frontAndBackPlanes
            type            empty;
    nut的瞬态云图截图看一下
    lwf
    @李东岳 好的
    nut的截图:
