  4. Wray-Agarwal湍流模型
Wray-Agarwal湍流模型
21 帖子 5 发布者 36.4k 浏览
    \frac{\p\alpha \rho \tilde{\nu}}{\p t} +\nabla\cdot \left( \alpha \rho \bfU \tilde{\nu} \right)- \nabla\cdot\left(\alpha \rho D_{\tilde{\nu}}\nabla \tilde{\nu} \right)
    = \alpha\rho \frac{C_{b2}}{\sigma_{\nu_t}} |\nabla \tilde{\nu}|^2
    +\alpha\rho C_{b1} \tilde{\nu}\tilde{S}
    -\alpha\rho C_{w1} f_w\frac{\tilde{\nu}^2}{{y}^2}+S_{\tilde{\nu}}
    S_{\tilde{\nu}}=-\alpha\rho f_{t2}\tilde{\nu}\tilde{S}+\alpha\rho f_{t1}(\Delta\bfU)^2+\alpha\rho f_{t2}\frac{C_{b1}}{\kappa^2}\frac{\tilde{\nu}^2}{y^2}
    我对比了一些,主要是多了个上面这个源项。所以OpenFOAM植入这个应该就是所谓的没有$f_{t2}$项与trip项的SA模型。但是这个$\Delta\bfU$还有后面的$\Delta x$怎么理解?:143:
    $\Delta\bfU$ is the difference between the velocity at the field point and that at the trip (on the wall)
    wangfei9088 大神
    @李东岳 李老师,说实话,我也没懂$f_{t1}$这个trip项。
    网页上把没有trip项的模型叫"Standard" Spalart-Allmaras One-Equation Model (SA),用于fully turbulent applications;有trip项的模型叫“Spalart-Allmaras One-Equation Model with Trip Term (SA-Ia)”,用于initiate transition。
    植入的话,低雷诺数SA模型,两个$f_{t2}$项是laminar region,肯定是需要的。至于$f_{t1}$项,就看实际是否需要了。
    在 中回复了 wangfei9088 最后由 编辑
    @wangfei9088
    A "trip" in the context of computational fluid dynamics (CFD) and the Spalart-Allmaras turbulence model refers to a turbulent trip. Specifically:
    A turbulent trip is a device used to trigger a transition from laminar to turbulent flow in a fluid dynamics experiment or simulation. Fluids can flow in either a smooth, laminar state or a chaotic, turbulent state depending on conditions like velocity, viscosity, and surface roughness.
    In CFD using the Spalart-Allmaras model, adding a "trip term" attempts to model the effects of an actual physical trip device that would be used in an experimental flow setup. This trip modeling triggers the transition to turbulence in the simulation.
    So in the sentence you referenced, the "trip term" refers to an addition made to the Spalart-Allmaras equations that mimics the effect of a physical turbulent trip, forcing a transition from laminar to turbulent modeling. This trip modeling can be important to accurately replicating real experimental conditions in the CFD simulation.
    A turbulent trip is a device...
    厉害了各位老铁。我知道了。感觉这个trip应该不需要植入,如果没有trip的话。那对于没有trip的SA模型,就是
    只需要搞ft2就可以。要简单不少。那个ft1太长了。
    wangfei9088 大神
    写于 最后由 wangfei9088 编辑
    没人试试SA么,那我还是把坑填上吧。:xiezuoye:
    @xpqiu 在 Wray-Agarwal湍流模型 中说:
    @李东岳 在 Wray-Agarwal湍流模型 中说:
    对,我也这么理解的。:xinxin2:
    含$f_{t2}$两项,不含$f_{t1}$的SA模型,of10版本。mySpalartAllmaras里wmake,pitzDaily里simpleFoam。感兴趣的可以试试,已测试,没问题,供参考。
    mySpalartAllmarasTurbulenceModel.tar.xz
    注:11楼和14楼的源项少了一个系数$C_{b1}$,应该是:
    S_{\tilde \nu} = -\alpha \rho C_{b1} f_{t2} \tilde \nu \tilde S + \alpha \rho \frac{C_{b1}}{\kappa ^2} f_{t2} \left[ \frac{\tilde \nu}{y} \right]^2
    一个流弊的低雷诺数SA模型在CFD中文网于2023年11月27日诞生!
  • 李东岳李 李东岳 被引用 于这个主题
    https://journals.sagepub.com/doi/abs/10.1177/09576509241236533
    这个文章里面把WA模型演变成了DES模型
    wangfei9088 大神
    @李东岳 没有下载权限,看不了:135:
  • W wangfei9088 被引用 于这个主题
    @wangfei9088 大佬,按照这种方式自定义湍流模型,会提示 Duplicate entry 的警告,直接忽略就可以吗?这个帖子提到不要有这种警告,就要复制很多文件,感觉挺麻烦
    Duplicate entry laminar in runtime selection table incompressibleMomentumTransportModel
    #0	/home/install/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x32) [0x7f0a93735072]
    wangfei9088 大神
    在 中回复了 coolhhh 最后由 wangfei9088 编辑
    @coolhhh 在 Wray-Agarwal湍流模型 中说:
    是的,这种加 libs 的方法就经常出现这种情况。直接忽略即可。
    不要有这种警告,就要复制很多文件
    是的,如果不想要这种警告,依赖这个模型的文件就都要修改。不难,但比较麻烦。
    @wangfei9088 感谢大佬:146: :146:
