  4. interIsofoam射流问题
interIsofoam射流问题
4 帖子 3 发布者 2.8k 浏览
    xiaoyangfoamer
    圆柱容器里面是液体,圆柱喷嘴喷出气体(喷嘴上部面转化为内部网格处理),使用interIsofoam求解器,主要想观察气体喷出后生成的气泡的形状和运动轨迹,网格由icem绘制转化至openfoam,checkmesh信息如下:
    Check mesh...
    Time = 0
    Mesh stats
        faces:            1851102
        internal faces:   1828728
        cells:            613305
        faces per cell:   6
        boundary patches: 5
        point zones:      0
        face zones:       3
        cell zones:       2
        hexahedra:     613305
        prisms:        0
        wedges:        0
        pyramids:      0
        tet wedges:    0
        tetrahedra:    0
        polyhedra:     0
    Checking topology...
        Boundary definition OK.
        Cell to face addressing OK.
        Point usage OK.
        Upper triangular ordering OK.
        Face vertices OK.
        Number of regions: 1 (OK).
        Patch               Faces    Points     Surface topology
        outlet              1485     1508     ok (non-closed singly connected)
        nozzlewall          1232     660      multiply connected (shared edge)
        bottom              616      660      ok (non-closed singly connected)
        pipewall            18172    18216    ok (non-closed singly connected)
        inlet               869      892      ok (non-closed singly connected)
        ".*"                22374    21760    multiply connected (shared edge)
    Detected 1232 bad edges (possibly relevant for finite-area)
    Checking faceZone topology for multiply connected surfaces...
        FaceZone            Faces    Points   Surface topology
        int_FLUID           1792538  612440   multiply connected (shared edge)
        int_FLUID_AIR       35321    13380    multiply connected (shared edge)
        int_INTERIOR1       869      892      ok (non-closed singly connected)
      <<Writing 624224 conflicting points to set nonManifoldPoints
    Checking basic cellZone addressing...
        CellZone            Cells        Points       Volume       BoundingBox
        FLUID               601139       612440       0.000704116  (-0.0149602 -0.0149572 0) (0.0149602 0.0149572 1)
        FLUID_AIR           12166        13380        1.92837e-09  (-0.000391458 -0.000391429 0) (0.000391458 0.000391429 0.004)
    Checking basic pointZone addressing...
        No pointZones found.
    Checking geometry...
        Overall domain bounding box (-0.0149602 -0.0149572 0) (0.0149602 0.0149572 1)
        Boundary openness (4.6938e-16 1.39741e-15 1.52826e-18) OK.
        Max cell openness = 4.03117e-16 OK.
        Max aspect ratio = 389.103 OK.
        Minimum face area = 2.38205e-10. Maximum face area = 7.65441e-06.  Face area magnitudes OK.
        Min volume = 5.02898e-14. Max volume = 1.47182e-08.  Total volume = 0.000704118.  Cell volumes OK.
        Mesh non-orthogonality Max: 35.2075 average: 4.51619
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 1.90366 OK.
    Mesh OK.
    现在存在的问题是虽然网格数只有60w,但计算开始时的时间步长在10e-5,随着计算过程的推进逐渐变小至10e-30,并且喷嘴上方喷出的气体应该转变为气泡分类而不是如下图所示的一个柱状区域,我想求助各位大佬,我这个是网格的问题还是算法的问题。
    ce80d0f4-9c56-4d64-aa19-983e04822c5e-image.png b44af5fe-5bec-4239-aeff-68ece601079b-image.png
    纯六面体看起来不是网格的问题。看起来像是设置的问题。60万网格不太好debug。
    xiaoyangfoamer
    @李东岳 感谢东岳老师的回复,设置我也贴一下:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSolution;
    solvers
        "alpha.phase1.*"
            nAlphaCorr      3;
            nAlphaSubCycles 1;
            alphaOuterCorrectors yes;
            cAlpha          0;
            isoFaceTol      1e-6;
            surfCellTol     1e-6;
            nAlphaBounds    3;
            snapTol         1e-12;
            clip            true;
            gardAlphaNormal false;
            MULESCorr       yes;
            nLimiterIter    3;
            solver          smoothSolver;
            tolerance       1e-8;
            relTol          0;
            orientationMethod   LS; //RDF
            splitWarpedFace     false;
            writePlicFields     false;
            mapAlphaField       true;
            nAlphaSubCycles     1;
            cAlpha              1;
        "pcorr.*"
           solver          GAMG;
            tolerance       1e-08;
            relTol          0.01;
            smoother        DIC;
            cacheAgglomeration no;
        p_rgh
           solver          GAMG;
            tolerance       1e-08;
            relTol          0.01;
            smoother        DIC;
        p_rghFinal
            $p_rgh;
            relTol          0;
            tolerance       1e-9;
        U
            tolerance       1e-07;
            relTol          0;
         UFinal
            $U;
            tolerance       1e-06;
            relTol          0;
         kFinal
            $k;
            tolerance       1e-06;
            relTol          0;
         epsilonFinal
            $epsilon;
            tolerance       1e-06;
            relTol          0;
         epsilon
            tolerance       1e-06;
            relTol          0;
        k
            tolerance       1e-06;
            relTol          0;
    PIMPLE
        momentumPredictor   yes;
        nOuterCorrectors    3;
        nCorrectors         5;
        nNonOrthogonalCorrectors 1;
        pRefPoint      (0.01 0.01 0.01);
        pRefValue      0;
    reconstructionSchemes
        alpha.phase1
            method          isoAlpha;
            isoAlphaMethod  isoAlpha;
            alpha           alpha.phase1;
            isoValue        0.5;
            surfaceCellSize 0;
            linearCorrection true;
            smoothNormals    true;
            nSmoothNormals   3;
            cellNormalMethod corrected;
            faceNormalMethod corrected;
    relaxationFactors
        fields
        equations
            ".*" 1;
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      fvSchemes;
    ddtSchemes
        default          CrankNicolson 1;
    gradSchemes
         default         Gauss linear ;
    divSchemes
        div(Phi,U)  Gauss linearUpwind grad(U);
         div(rhoPhi,U)   Gauss limitedLinearV 1;
        div(phi,alpha.phase1)  Gauss  interfaceCompression vanLeer 3;
        div(phirb,alpha) Gauss interfaceCompression;
        div(phi,k)       Gauss upwind;
        div(phi,epsilon) Gauss upwind;
        div((muEff*dev(T(grad(U))))) Gauss linear;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
        cAlpha          2;
    wallDist
        method          meshWave;
    fluxRequired
        default         no;
        p_rgh;
        pcorr;
        alpha.phase1;
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      setFieldsDict;
    defaultFieldValues
        volScalarFieldValue alpha.phase1 1
    regions
        cylinderToCell
            p1 (0 0 0);
            p2 (0 0 0.004);
            radius 0.0003925;
            fieldValues
                volScalarFieldValue alpha.phase1 0
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      controlDict;
    application     interIsoFoam;
    startFrom       startTime;
    startTime       0;
    stopAt          endTime;
    endTime         0.2;
    deltaT          0.0001;
    writeControl    adjustableRunTime;
    writeInterval   0.005;
    purgeWrite      0;
    writeFormat     ascii;
    writePrecision  6;
    writeCompression uncompressed;
    timeFormat      general;
    timePrecision   6;
    runTimeModifiable yes;
    adjustTimeStep  yes;
    maxCo           5;
    maxAlphaCo      1;
    maxDeltaT       0.01;
    libs            ("libfiniteVolume.so" "libsampling.so");
    functions
      bubbleTracking
            type            surfaces;
            libs            ("libsampling.so");
            surfaceFormat   vtk;
            fields          (alpha.phase1 U);
            surfaces
                bubbleSurface
                    type            isoSurface;
                    isoField        alpha.phase1;
                    isoValue        0.5;
                    interpolate     true;
            executionInterval 5;
      gasVolumeFraction
           type                 volFieldValue;
           libs                 ("libfieldFunctionObjects.so");
           enabled              true;
           operation            average;
           fields               (alpha.phase1);
           mean                 on;
           base                 time;
           writeControl         timeStep;
           writeInterval        1;
           log                  true;
           valueOutput          true;
           writeFields          false;
           surfaceFormat        none;
           format               csv;
    FoamFile
        format      ascii;
        class       volScalarField;
        location    "0";
        object      epsilon;
    dimensions      [0 2 -3 0 0 0 0];
    internalField   uniform 1e-6;
    boundaryField
        outlet
           type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 1.04e5;
        nozzlewall
            type            epsilonWallFunction;
            value           uniform 1e-6;
        bottom
            value           uniform 1e-6;
        pipewall
            value           uniform 1e-6;
    FoamFile
        version     2.0;
        format      ascii;
        object      k;
    boundaryField
        outlet
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 11.34;
        nozzlewall
            type            kqRWallFunction;
            value           uniform 1e-6;
        bottom
            value           uniform 1e-6;
        pipewall
            value           uniform 1e-6;
    FoamFile
        version     2.0;
        format      ascii;
        object      nut;
    boundaryField
        outlet
            type             calculated;
            value           uniform 0;
        inlet
            type            calculated;
            value           uniform 0;
        nozzlewall
            value           uniform 0;
        bottom
        pipewall
            value           uniform 0;
    FoamFile
        version     2.0;
        format      ascii;
        object      p_rgh;
    internalField   uniform 0;
    boundaryField
        outlet
            type            totalPressure;
            p0              uniform 0;
        inlet
            value           uniform 0;
        nozzlewall
            value           uniform 0;
        bottom
            value           uniform 0;
        pipewall
            value           uniform 0;
    具体就是这样,设定喷气体,容器里面充满液体,改了一个月也没怎么收敛,头大得很,之前画了个200w的网格,△t很小就调粗网格了,能够调成功的话打算在捕获相界面的方法上下点功夫。
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    @xiaoyangfoamer
    你试试这种方法:初始化的时候就在喷嘴后面设定一小段的气体柱,很短就可以。
    之前用Basilisk的时候,看到过这样的处理,说是让求解器好收敛一些。不知道OpenFOAM是不是这样。
