  4. 对旋转机械进行计算时的错误提示
对旋转机械进行计算时的错误提示
18 帖子 5 发布者 23.8k 浏览
    lllwonderliquid
    大家好,最近在做旋转机械内流场的计算工作,使用了AMI动静交接面,采用MRF坐标系,可是当我开始计算时,却出现了以下错误提示。。。觉得很可能是边界条件设置有问题。。贴一下边界条件设置文件,如下。求大神指教!
    lizehao@lizehao-Z97-HD3:~/openFoam/run/tubulence_model_test_on_centrifugal_pump/mesh5/merge_grid$ simpleFoam |tee simpleFoam.log
    Build  : 4.1
    Exec   : simpleFoam
    Date   : Dec 08 2017
    Time   : 11:09:02
    Host   : "lizehao-Z97-HD3"
    PID    : 30537
    Case   : /home/lizehao/openFoam/run/tubulence_model_test_on_centrifugal_pump/mesh5/merge_grid
    nProcs : 1
    Create time
    Create mesh for time = 0
    SIMPLE: convergence criteria
        field p	 tolerance 1e-05
        field U	 tolerance 1e-05
        field k	 tolerance 1e-05
        field epsilon	 tolerance 1e-05
        field nut	 tolerance 1e-05
    Reading field p
    Reading field U
    AMI: Creating addressing and weights between 18792 source faces and 2424 target faces
    AMI: Patch source sum(weights) min/max/average = 0.992729, 1.00082, 0.999897
    AMI: Patch target sum(weights) min/max/average = 0, 1.00061, 0.580281
    AMI: Creating addressing and weights between 7722 source faces and 3861 target faces
    AMI: Patch source sum(weights) min/max/average = 0.0916406, 1, 0.994738
    AMI: Patch target sum(weights) min/max/average = 0, 1, 0.877149
    kEpsilonCoeffs
        Cmu             0.09;
        C1              1.44;
        C2              1.92;
        C3              -0.33;
        sigmak          1;
        sigmaEps        1.3;
    Creating MRF zone list from MRFProperties
        creating MRF zone: MRF1
    Starting time loop
    Time = 1
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0389849, No Iterations 2
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0580972, No Iterations 2
    smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0935053, No Iterations 1
    #3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
    #4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
    #5  ? at ??:?
    #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #7  ? at ??:?
    U文件,进口fixedValue,出口zeroGradient,壁面noslip,交接面cyclicAMI
        version     2.0;
        format      ascii;
        class       volVectorField;
        object      U;
    internalField   uniform (2.744 0 0);
    boundaryField
        wall1_runner
            type            noSlip;
        wall2_runner
            type            noSlip;
        wall3_runner
            type            noSlip;
        wall4_runner
            type            noSlip;
        interface_runner
            type            cyclicAMI;
            value           uniform (2.744 0 0);
        interface1_runner
            type            cyclicAMI;
        interface2_runner
            type            cyclicAMI;
        wall2_suction
            type            noSlip;
        outflow_suction
            type            noSlip;
        wall1_suction
            type            noSlip;
        inlet
            type            fixedValue;
        interFace1_suction
            type            cyclicAMI;
        interFace2_suction
            type            cyclicAMI;
        wall1_volute
            type            noSlip;
        interface_volute
            type            cyclicAMI;
        wall2_volute
            type            noSlip;
        outlet_volute
            type            zeroGradient;
    P文件,进口及壁面zeroGradient,出口fixedValue,交接面cyclicAMI
        version     2.0;
        format      ascii;
        class       volScalarField;
        object      p;
    internalField   uniform 0;
    boundaryField
        wall1_runner
            type            zeroGradient;
        wall2_runner
            type            zeroGradient;
        wall3_runner
            type            zeroGradient;
        wall4_runner
            type            zeroGradient;
        interface_runner
            type            cyclicAMI;
            value           uniform 0;
        interface1_runner
            type            cyclicAMI;
            value           uniform 0;
        interface2_runner
            type            cyclicAMI;
            value           uniform 0;
        wall2_suction
            type            zeroGradient;
        outflow_suction
            type            zeroGradient;
        wall1_suction
            type            zeroGradient;
        inlet
            type            zeroGradient;
        interFace1_suction
            type            cyclicAMI;
            value           uniform 0;
        interFace2_suction
            type            cyclicAMI;
            value           uniform 0;
        wall1_volute
            type            zeroGradient;
        interface_volute
            type            cyclicAMI;
            value           uniform 0;
        wall2_volute
            type            zeroGradient;
        outlet_volute
            type            fixedValue;
            value           uniform 0;
    k文件,进口fixedValue,出口inletoutlet,壁面kqRWallFunction,交接面cyclicAMI
        version     2.0;
        format      ascii;
        location    "0";
        object      k;
    internalField   uniform 0.01;
    boundaryField
        wall1_runner
            value           uniform 0.01;
        wall2_runner
            value           uniform 0.01;
        wall3_runner
            value           uniform 0.01;
        wall4_runner
            value           uniform 0.01;
        interface_runner
            type            cyclicAMI;
        interface1_runner
            type            cyclicAMI;
        interface2_runner
            type            cyclicAMI;
        wall2_suction
            value           uniform 0.01;
        outflow_suction
            value           uniform 0.01;
        wall1_suction
            value           uniform 0.01;
        inlet
            type            fixedValue;
            value           uniform 0.01;
        interFace1_suction
            type            cyclicAMI;
        interFace2_suction
            type            cyclicAMI;
        wall1_volute
            value           uniform 0.01;
        interface_volute
            type            cyclicAMI;
        wall2_volute
            value           uniform 0.01;
        outlet_volute
            type            inletOutlet;
            inletValue      $internalField;
    epsilon文件,进口fixedValue,出口inletoutlet,壁面epsilonWallFunction,交接面cyclicAMI
        version     2.0;
        format      ascii;
        location    "0";
        object      epsilon;
    dimensions      [0 2 -3 0 0 0 0];
    internalField   uniform 0.0095;
    boundaryField
        wall1_runner
            value           uniform 0.0095;
        wall2_runner
        wall3_runner
        wall4_runner
        interface_runner
            type            cyclicAMI;
        interface1_runner
            type            cyclicAMI;
        interface2_runner
            type            cyclicAMI;
        wall2_suction
        outflow_suction
        wall1_suction
        inlet
            type            fixedValue;
        interFace1_suction
            type            cyclicAMI;
        interFace2_suction
            type            cyclicAMI;
        wall1_volute
        interface_volute
            type            cyclicAMI;
        wall2_volute
        outlet_volute
            type            inletOutlet;
    只能看出来
    可能除以0了,但是并不知道是哪里出去了,需要更深度的debug
    lllwonderliquid
    嗯嗯:crying: 我看到CFD-online上一些前辈们也是这样说,然后我就懵圈了,完全不知道应该怎样去debug,不知道应该遵循一个怎样的流程或原则。。:crying:
    为什么同时使用AMI和MRF?
    lllwonderliquid
    嗯。。因为网格划分时把动静部件分开划分,然后合并的时候有交接面,所以用了AMI。。然后我是采用多重参考系定义速度。。难道它们之间是有矛盾的?:big_mouth:
    D 2 条回复 最后回复
    这样的话你用AMI就不需要用MRF了 :big_mouth:
    lllwonderliquid
    嗯。。可我目前算的是稳态,不用MRF的话怎么处理内部的旋转部件呢:surprised:
    估计你之前用过Fluent,OpenFOAM里面MRF也可以瞬态,拟瞬态。
    Y 1 条回复 最后回复
    dzw05 超神
    在 中回复了 lllwonderliquid 最后由 编辑
    @lllwonderliquid 你可以不用设定AMI边界条件。这个和fluent可能不一样,也就是说动静网格可以是一个整体,但是把其中的一部分网格设定为rotater。至少我这样算是成功了。
    自主匠心,普惠仿真。
    dzw05 超神
    @lllwonderliquid 或者另一个思路去理解。你分别生成了动、静区域,但是这两个区域的交界面必须一致。这是和fluent里不同的地方。我也一直试图理解AMI边界的用法,按理说和fluent一样是可行的,但是实际使用的时候并不行。
    自主匠心,普惠仿真。
    yuanlee2011
    @李东岳 你好!之前看过你在cfd-online的回复(https://www.cfd-online.com/Forums/openfoam-programming-development/153989-modified-pimplefoam-solver-mrfpimplefoam-solver.html),我想知道pimpleFoam(2.3.x)能否可以直接使用MRF吗?只需要添加fvOptions即可?
    只需要添加fvOptions即可?
    是的。主要是多相那面代码处理有点甚至超过了Weller的高度。单相这面容易。
    yuanlee2011
    写于 最后由 yuanlee2011 编辑
    @李东岳 也就是说MRF通过fvOptions(U)对动量方程产生作用?若在pimpleFOAM中添加温度T方程,需要考虑MRF作用吗,是否得添加fvOptions(T)?
    在 中回复了 yuanlee2011 最后由 编辑
    @yuanlee2011
    要的,简单添加
    fvOptions(T);
    fvOptions.constrain(TEqn);
    fvOptions.correct(T);
    即可,这就是面向对象的方便之处。是不是要比Fluent简单点?我不清楚Fluent..没准Fluent那面更简单,哈哈。
    Y 2 条回复 最后回复
    yuanlee2011
    @李东岳 非常感谢!
    yuanlee2011
    @李东岳 有很多帖子(尤其与Fluent相关)都表明MRF只适用于稳态求解,不知道在Openfoam中能否实现MRF瞬态求解? 是否有相关的求解器(已验证其准确性)?
    目前OpenFOAM这面采用MRF做计算已经发表的文章有很多,包括我用OpenFOAM计算的旋转搅拌器。在这里贴一个其他课题组的:http://www.sciencedirect.com/science/article/pii/S0892687516301789
    有关Fluent,我的理解只局限于理论,你可以参考英文版的理论指南里面的论述。使用MRF进行瞬态模拟是可能的。
    但同时我也注意到很多用Fluent的用户告诉我说Fluent中的MRF不能用于瞬态计算。由于我没有用过Fluent,我自己也有点迷惑Fluent那面具体怎么个情况。
    不过可以确定的是,理论上是可以的
  • 液 离线
    液 离线
    液固两相流
    @lllwonderliquid 请问你的问题目前解决了吗?
    我目前也在使用MRF以及AMI边界条件进行计算,但是碰到了与你类似的问题
