  4. kEpsilon和kOmegaSST仍未解决
10 帖子 3 发布者 12.0k 浏览
  • E 离线
    E 离线
    Exthan
    等热流加热圆管流采用kOmegaSST模型在buoyantSimple和rhoSimple均进行了尝试,发散,虽然有类似贴,但仍未解决该问题。采用kEpsilon求解仍然发散,k,epsilon以及omega都采用公式进行估算,但仍然发散,请大家帮忙查看是否是边界问题:
    alphat:copy自带算例,湍流prt默认,该如何改?有公式吗?
        object      alphat;
    dimensions      [1 -1 -1 0 0 0 0];
    internalField   uniform 0;
    boundaryField
        heatflux
            type            compressible::alphatWallFunction;
            Prt             0.85;
            value           uniform 0;
        outlet
            type            calculated;
        inlet
            type            calculated;
    k
        heatflux
            value           uniform 0;
        outlet
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 2.5e-3;
    nut:查看资料显示对于不可压缩使用nut,对于可压缩则使用mut,但是使用mut系统报错,{查不到nut},不太清楚原因,求各位老师指导。
        heatflux
            type            nutUWallFunction;
            value           uniform 0;
        outlet
            type            calculated;
            value           uniform 0;
        inlet
            type            calculated;
            value           uniform 0;
    omega
        heatflux
            type            omegaWallFunction;
            value           uniform 0.12;
        outlet
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 0.12;
    p:这里给的是rhoSimple算例
        heatflux
        outlet
            type            fixedValue;
            value           uniform 8.8e6;
        inlet
            type            zeroGradient;
    T:这个地方有个Ta,一般出现在热辐射中,但是不给Ta就会报错,就给了个常温
     heatflux
            type            externalWallHeatFluxTemperature;
            mode            flux;
            q               uniform 6000;
            Ta              constant 300;
            kappaMethod     fluidThermo;
        outlet
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 298.15;
    U
     heatflux
            type            noSlip;
        outlet
            type            zeroGradient;
        inlet
            type            flowRateInletVelocity;;
            massFlowRate    0.001;
            extrapolateProfile yes;
            rho             rho;
            rhoInlet        795.55;
    此外,还计算了kEpsilon模型,下面给出epsilon
     heatflux
            value           uniform 4e-06;
        inlet
            type            fixedValue;
        outlet
            type            zeroGradient;
    根据错误log文件,不太确定是否为离散格式存在的问题,下面贴出fvScheme和矩阵求解器
    gradSchemes
        default             Gauss linear;
        default             none;
        div(phi,e)          bounded Gauss upwind;
        div(sigma)                  Gauss linear;
        div((nu*dev2(T(grad(U)))))  Gauss linear;
        div((nuM*grad(U)))          Gauss linear;
        div(phid,p)         Gauss upwind;
        div(phi,Ekp)        bounded Gauss upwind;
        div(phi,U)      Gauss limitedLinear 1;
        div(phi,K)      Gauss limitedLinear 1;
        div(phi,h)      Gauss limitedLinear 1;
        div(phi,k)      Gauss limitedLinear 1;
        div(phi,epsilon) Gauss limitedLinear 1;
        div(phi,omega) bounded Gauss limitedLinear 0.2;
        div((phi|interpolate(rho)),p) Gauss limitedLinear 1;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method meshWave;
    如果网格小,可以把算例处理干净发上来
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @东岳 感谢老师回复,这套网格可能稍微大一些,算例中还加有其他的库。我使用相同的设置对二维的平板也进行了计算,除了说除数为0外,下面的原因和求解器有关吗?
    5] #0  [7] #0  [8] #0  [9] #0  [10] #0  [11] #0  [12] #0  [13] #0  [14] #0  [15] #0  [17] #0  [18] #0  [19] #0  [20] #0  [22] #0  [23] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
    [5] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [7] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [8] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [9] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [10] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [11] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [5] #2  ? at ??:?
    [7] #2  ? at ??:?
    [8] #2  ? at ??:?
    [9] #2  ? at ??:?
    [10] #2  ? at ??:?
    [11] #2  ? in "/lib64/libpthread.so.0"
    [5] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [7] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [8] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [9] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [10] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [11] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
    [12] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [13] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [14] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [15] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [17] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [18] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [19] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [20] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [22] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [23] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [5] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [7] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [8] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [9] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [10] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [11] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [5] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [7] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [8] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [9] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [10] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [11] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [7] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [8] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [9] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, un[11] #2  ? in "/lib64/libpthread.so.0"
    checkMesh看一下?还有你报错是出现在什么位置,把你的log文件从开头到报错的地方都列出来看看。
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    在 中回复了 cccrrryyy 最后由 编辑
    @cccrrryyy 感谢.下面是我的checkMesh和输出log文件,稍后贴出完整e.log文件
        Patch               Faces    Points   Surface topology
        frontAndBack        80000    82082    ok (non-closed singly connected)
        top                 1000     2002     ok (non-closed singly connected)
        bottom              1000     2002     ok (non-closed singly connected)
        inlet               40       82       ok (non-closed singly connected)
        outlet              40       82       ok (non-closed singly connected)
    Checking geometry...
        Overall domain bounding box (0 0 0) (0.1 0.004 0.001)
        Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
        Mesh has 2 solution (non-empty) directions (1 1 0)
        All edges aligned with or perpendicular to non-empty directions.
        Boundary openness (-2.78353e-18 -1.04095e-15 -1.31454e-15) OK.
        Max cell openness = 1.65436e-16 OK.
        Max aspect ratio = 1 OK.
        Minimum face area = 1e-08. Maximum face area = 1e-07.  Face area magnitudes OK.
        Min volume = 1e-11. Max volume = 1e-11.  Total volume = 4e-07.  Cell volumes OK.
        Mesh non-orthogonality Max: 0 average: 0
        Non-orthogonality check OK.
        Face pyramids OK.
        Max skewness = 9.29949e-13 OK.
    Mesh OK.
    End
    输出log文件
    Starting time loop
    Time = 1
    GAMG:  Solving for Ux, Initial residual = 1, Final residual = 0.0680002, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 1, Final residual = 0.0275716, No Iterations 2
    GAMG:  Solving for e, Initial residual = 1, Final residual = 0.0497346, No Iterations 1
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0902438, No Iterations 32
    time step continuity errors : sum local = 1340.36, global = -1154.13, cumulative = -1154.13
    GAMG:  Solving for omega, Initial residual = 0.150676, Final residual = 0.0121053, No Iterations 4
    GAMG:  Solving for k, Initial residual = 1, Final residual = 0.0852085, No Iterations 1
    ExecutionTime = 0.29 s  ClockTime = 1 s
    Time = 2
    GAMG:  Solving for Ux, Initial residual = 0.998917, Final residual = 0.01403, No Iterations 1
    GAMG:  Solving for Uy, Initial residual = 0.951893, Final residual = 0.0298228, No Iterations 1
    GAMG:  Solving for e, Initial residual = 0.97607, Final residual = 0.00132126, No Iterations 1
    GAMG:  Solving for p, Initial residual = 0.00465283, Final residual = 0.000414147, No Iterations 2
    time step continuity errors : sum local = 555474, global = 91950.9, cumulative = 90796.8
    =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
    =   PID 7683 RUNNING AT node295
    =   EXIT CODE: 8
    =   CLEANING UP REMAINING PROCESSES
    =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
  • E 离线
    E 离线
    Exthan
    错误log,稍微删减了一点
    [2] #0  [4] #0  [6] #0  [9] #0  [11] #0  [7] #0  [12] #[14] #0  [17] #0  [15] 0  [21] [22] [23] #0  [19] #[20] #0  #0  #0  0  #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[10] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
    [2] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [4] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [6] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [2] #2  ? at ??:?
    [4] #2  ? at ??:?
    [6] #2  ? at ??:?
    [7] #2  ? at ??:?
    [9] #2  ? at ??:?
    [10] #2  ? at ??:?
    [11] #2  ? at ??:?
     at ??:?
     at ??:?
    [12] #1   at ??:?
    [23] #1  [19] #1  Foam::sigFpe::sigHandler(int) at ??:?
     at ??:?
    [17] #1  Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int) at ??:?
    [21] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [22] #1  Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int)[14] #1  Foam::sigFpe::sigHandler(int)[15] #1  Foam::sigFpe::sigHandler(int) in "/lib64/libpthread.so.0" in "/lib64/libpthread.so.0"
     in "/lib64/libpt
    hread.so.0"
    [11] #3  [10] #3  [4] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[2] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[6] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[7] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[9] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
     at ??:?
     at ??:?
    [7] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const[2] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [4] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const[6] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [2] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [4] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [6] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [2] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [4] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [6] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [9] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [10] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [11] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [12] #2  ? at ??:?
    [14] #2  ? at ??:?
    [15] #2  ? at ??:?
    [17] #2  ? at ??:?
    [19] #2  ? at ??:?
    [20] #2  ? at ??:?
    [21] #2  ? at ??:?
    [22] #2  ? at ??:?
    [23] #2  ? at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
    [2] #7  [4] #7  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[6] #7  [7] #7  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[9] #7  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[10] #7  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[11] #7  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/lib64/libpthread.so.0"
    [12] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [14] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [17] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [19] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [20] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [21] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [22] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/lib64/libpthread.so.0"
    [23] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int)[15] #3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
    [2] #8   at ??:?
    [4] #8   at ??:?
    [6] #8   at ??:?
    [7] #8   at ??:?
    [9] #8   at ??:?
    [10] #8   at ??:?
    [11] #8  Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [2] #9   at ??:?
    [4] #9   at ??:?
    [6] #9   at ??:?
    [7] #9   at ??:?
    [9] #9   at ??:?
    [10] #9   at ??:?
    [11] #9  Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve() at ??:?
    [2] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [4] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [6] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [7] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [9] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [10] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [11] #10  Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    [12] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [14] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [15] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [17] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [19] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [20] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [21] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [22] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [23] #4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
    [2] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [4] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [6] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [7] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [9] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [10] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [11] #11  Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >, Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
    [2] #12   at ??:?
    [4] #12   at ??:?
    [6] #12   at ??:?
    [7] #12   at ??:?
    [9] #12   at ??:?
    [10] #12   at ??:?
    [11] #12  ??????? at ??:?
    [2] #13  __libc_start_main at ??:?
    [4] #13  __libc_start_main at ??:?
    [6] #13  __libc_start_main at ??:?
    [7] #13  __libc_start_main at ??:?
    [9] #13  __libc_start_main at ??:?
    [10] #13  __libc_start_main at ??:?
    [11] #13  __libc_start_main in "/lib64/libc.so.6"
    [2] #14   in "/lib64/libc.so.6"
    [4] #14   in "/lib64/libc.so.6"
    [6] #14   in "/lib64/libc.so.6"
    [7] #14   in "/lib64/libc.so.6"
    [9] #14   in "/lib64/libc.so.6"
    [10] #14   in "/lib64/libc.so.6"
    [11] #14  ??????? at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
    [17] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
     at ??:?
     at ??:?
     at ??:?
     at ??:?
    [14] [19] ##[22] #5  5  5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) constFoam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) constFoam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const[23] #5  [15] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) constFoam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [20] # at ??:?5
    Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const[21] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    [12] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const
    这个是你说的二维平板算例是吧?我说的log文件从头开始是指从最最开始的地方,我想看下模型建立过程中有没有别的问题(湍流呀热物性呀之类的)。你用的就是rhoSimpleFoam么,还是自己有改过?
    E 2 条回复 最后回复
  • E 离线
    E 离线
    Exthan
    @cccrrryyy 热物性库修改过,湍流未做修改,热物性库做过层流验证是可以的。因为是在超算计算,所以错误信息和输出信息是分开的
    SIMPLE: convergence criteria
        field p      tolerance 0.001
        field U      tolerance 0.0001
        field e      tolerance 0.001
        field "(k|epsilon|omega)"    tolerance 0.001
        type            heTabularThermo;
        mixture         pureMixture;
        transport       tabular;
        thermo          hTabular;
        equationOfState tabularEOS;
        specie          specie;
    Reading field T
    Reading field U
    pressureControl
        pMax 1.76e+07
        pMin 880000
    Creating turbulence model
    RAS
        RASModel        kOmegaSST;
        turbulence      on;
        printCoeffs     on;
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
    No MRF models present
    Starting time loop
    Time = 1
    Time = 2
    =   EXIT CODE: 8
  • E 离线
    E 离线
    Exthan
    @cccrrryyy
    第82行有个浮点溢出
    Pstream initialized with:
     78     floatTransfer      : 0
     79     nProcsSimpleSum    : 0
     80     commsType          : nonBlocking
     81     polling iterations : 0
     82 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
     83 fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
     84 allowSystemOperations : Allowing user-supplied system call operations
     85
     86 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //
     87 Create time
    插值从表格里面做热物性吧?那估计是超临界啥的。算例本身算起来可能是会有点不好收敛。你层流验证的时候好收敛么,还是也很难收敛?如果层流很好收敛但湍流不收敛,那大概率是湍流的边界问题;如果层流本身也很难收敛,那就可以去找别的原因了。其实你可以试试,同样的设置下把热物性换成普通的(理想气体之类的)看看能不能算,这样也能排除一些问题。
    单看log文件有两点我觉得值得考虑。1、你设置了pressureControl,限定了压力的最大最小值,你本身的工况是在这个压力范围之内么? 2、这个可能性比较低。你可以把SIMPLE的convergence criteria调小一些,看起来你的速度方程解了1步就收敛了,对线性求解器来说好像太容易了点。
