  4. eddy,vortex和whirl的区别
3 帖子 3 发布者 6.6k 浏览
  • P 离线
    P 离线
    peak_han
    英文文献中经常出现这三个词,它们三个又什么区别?傻傻分不清楚
    复制quora上的:
    Vortex is nothing but rotationally of flow on their own axis vorticity is talked in individuality but eddies are talked in plural means many of vortices are eddies
    Example of vorticity is whirlpool of water in washing machine it has no gap between them but in case of eddies there is a gap between them ex is separation of flow on the airfoil in eddies back motion is created as you had seen on the airfoil
    swril is like eddies in this there is a creation of backmotion and building of gap
    Eddies is created due to generation of swril
    In vortex motion the flow rotates on its own axis but does not translates
    Turbulence is basically the chaos eddies and swirling produces turbulence
    Vortex is present both in laminar and turbulence region but it's nature changes or shape changes
    Swirling are very popular for fuel mixing in engines there are swirl ratio and tumblr ratio which decide the mixing of fluid how good they mix
    2
    Vortex is fluid rotating about an axis and it can be of vortex tubes or vortex bundles or infinite vortex or vortex sheet.
    Swirl is a flow with angular momentum. The flow axially moves and also rotates and spread about the axis along which it moves.
    Eddies are blobs of fluids looking like ball and rotates in arbitrary directions as dictated by the flow gradients and they can break up to form smaller eddies or merge up to form larger eddies.
    这个放在他们搞涡那面,估计能讨论一上午 :duang:
    我个人也不太熟悉。在我的文章里面,也不太关心涡的情况。
