  4. OpenFOAM中LES输出最终残差问题
7 帖子 3 发布者 7.8k 浏览
    coolhhh 神
    LES模拟,调用了residuals函数输出残差,但发现输出的结果是每步计算的初始残差。根据函数的描述也是输出 initial residuals。请问大家有什么方法可以输出final residuals吗?
        \\  /    A nd           | Version:  8
         \\/     M anipulation  |
    Description
        For specified fields, writes out the initial residuals for the first
        solution of each time step; for non-scalar fields (e.g. vectors), writes
        the largest of the residuals for each component (e.g. x, y, z).
    #includeEtc "caseDicts/postProcessing/numerical/residuals.cfg"
    fields (p U);
    https://www.cfd-online.com/Forums/openfoam-solving/181927-buoyantsimplefoam-not-plotting-residuals.html#post632303
    是因为没开预测么?
    我更关注的是,为什么你不关注initial residual,而是关注final residual
    coolhhh 神
    @bestucan
    1. 好像不是这个问题,下面是我输出的 log.pisoFoam 和 对应的 residuals.dat。 residuals.dat 输出的都是每步计算开始的 Initial residual,好像无法选择输出每步计算最后的 Final residual
    2. 计算的log.pisoFoam文件
    Time = 0.0015
    Courant Number mean: 0.18933236 max: 3.0134083
    smoothSolver:  Solving for Ux, Initial residual = 0.94279208, Final residual = 4.1036105e-07, No Iterations 4
    smoothSolver:  Solving for Uy, Initial residual = 0.24479151, Final residual = 9.6080469e-07, No Iterations 3
    smoothSolver:  Solving for Uz, Initial residual = 0.21776409, Final residual = 8.4350179e-07, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.0048258603, Final residual = 0.00021860641, No Iterations 18
    GAMG:  Solving for p, Initial residual = 0.17069422, Final residual = 0.0063724156, No Iterations 2
    time step continuity errors : sum local = 5.5286369e-05, global = 2.8590342e-06, cumulative = 2.6884486e-05
    GAMG:  Solving for p, Initial residual = 0.025078242, Final residual = 0.0012531841, No Iterations 16
    GAMG:  Solving for p, Initial residual = 0.058320856, Final residual = 0.0028998385, No Iterations 27
    time step continuity errors : sum local = 2.6808848e-06, global = -4.4628639e-09, cumulative = 2.6880023e-05
    GAMG:  Solving for p, Initial residual = 0.017046775, Final residual = 0.0008362502, No Iterations 36
    GAMG:  Solving for p, Initial residual = 0.0020386497, Final residual = 9.9487967e-07, No Iterations 305
    time step continuity errors : sum local = 8.7201563e-10, global = -1.7811338e-12, cumulative = 2.6880021e-05
    ExecutionTime = 16.02 s  ClockTime = 16 s
    1. 对应输出的 residuals.dat 文件
    # Residuals
    # Time          	p               	Ux              	Uy              	Uz
    0               	N/A	N/A
    0.0005          	1.00000000e+00	1.00000000e+00	1.00000000e+00	1.00000000e+00
    0.001           	3.79477181e-03	9.31777378e-01	3.20163786e-01	3.21921547e-01
    0.0015          	4.82586027e-03	9.42792079e-01	2.44791510e-01	2.17764088e-01
    coolhhh 神
    李老师,我本来是想输出最终残差后,画个最终残差曲线看下每步计算最后的收敛情况。我是加载入口脉动风计算,初始残差每步都是会比较大,所以比较关注每步计算的最终残差效果。
    bestucanB 1 条回复 最后回复
    在 中回复了 coolhhh 最后由 编辑
    @coolhhh
    终端切换到 log.pisoFoam 所在的文件夹,运行这句
    grep 'Final residual' log.pisoFoam | awk -F ',' '{print $3}' | cut -d "=" -f2 > finRes.log
    coolhhh 神
    @bestucan 完美解决,谢谢大佬:146:
